When I clean a 7th injector I use Berrymans B12 cleaner (spray) and a soft bristle brush to clean the injector. Then I flow clean the 7th injector using a bottle w/#4 strataflex line with an air charge port(a/c system cleaner bottles). I fill the bottle about a 1/4 with Berrymans B12 cleaner, pressure the bottle, use Pro Tech Tool to activate the 7th injector and watch the spray pattern. Reset the 7th injector adaptive factor so the eecu knows it has been cleaned, that way it will have proper delivery when performing a regen. If it has an air purge system then make sure it is working or that would cause the 7th injector to soot over quicker than usual.
It should have some air pressure with the key on. If not, the air regulator and on/off solenoid is usually located at the air dryer. Voltage is supplied to the solenoid by the air dryer purge heater - there is a jumper harness that connects to the purge valve heater and runs over to the solenoid valve.
https://www.bigmacktrucks.com/topic/42162-7nth-injector/#findComment-307423
