I really don't think I can get good enough pics to show,but just picture your normal everyday steel MH/RW frame rail cut off under the cab,then they slid the aluminum rail inside and bolted it.
That's pretty interesting. In the under the cab area RW/MH steel frame has higher section than at rear. Does this mean that aluminum rail has the contact area at the side and the top only?
Another question: do I remeber correctly that all RW1 both aluminium and steel frames had the split area with bolts under a cab?
Heres a top view of where the steel front frame section joins the aluminum on my superliner I will get better pics from underneath when I decide to get dirty later on today.
Thank you for sharing.
Just can't figure out exactly where that connection located. Right behind the battery box? Did you do those photos from under the hood?
