I did some L vent windows and the rubber from Chalmers was $240 for the set. The rubber is now no longer available. I used some reproduction locking chrome handles from an early 40's Ford and a stud repair kit because the originals were seized on the stud. The look is a little different but not too bad. That was about $60.00 or so I think. The chrome was redone and was around $325.00. $75.00 was for new glass. My labor rate is $.01/ hour. A few bucks for some rattle can black and gas to run to the chrome shop brings the total to about $775.
I don't know the price of the B rubber vent kit but that will give you an idea.
about the same price give or take. all depends if you have the ambition to cut the rivets on a B model window, have the parts chromed, put it back together and deal with the broken handle issue or you wanna be lazy and bolt a pair right in and move on. I have done a few pairs, they are not that bad. the rubber parts are probably a little over 300 now from steele rubber products plus you need the glass run for the back side.
