Ive got an 88 DM688sx with a maxitorque 5 speed. Transmission has 4 hours on the rebuild with no issues until it took a few tries to get it into reverse. I'm not sure what's going on here because when there's less than 60 psi in the tanks the reverse shifter engages no problem but once the truck builds over 60lbs the shifter won't engage. I'm not sure if I should replace the valve in the shifter head or if I should pull the reverse shifter apart. Any advice would be appreciated. Thanks Trevor
https://www.bigmacktrucks.com/topic/42469-reverse-shifter-problem/
Welcome to the forum
could be a number of things but I would start with simple things first
is the air regulator hooked up the correct way ??
did something get in the air lines when the box was out and cause a blockage ?
if you apply shop air strait to the air ram on the box does it shift ok ???
Paul
Regulator is hooked up right. I pulled the lines back off to see if there was any visible blockage. I just can't figure out why when I have more air in the system the shifter won't engage but when I don't even have enough air to release the parking brake, it engages fine
I have 84dm688sx I had a rebuild on trans done I broke the main shaft on trans I had the same problem after rebuild brought back and it was leaking air bolt was missing installed bolt and it worked after that properly . Every once in a while it won't go I flip lever a couple times it will pop in check for missing bolts. does your truck drop air pressure quickly ?
Sent from my iPhone using Tapatalk
