Help with gaskets
Just get some gasket shellac and some gasket paper, problem solved.
Not sure where you live but I know Autozone is nationwide
http://www.autozone.com/sealants-glues-adhesives-and-tape/indian-head-gasket-shellac?filterByKeyWord=gasket+shellac&fromString=search
http://www.autozone.com/sealants-glues-adhesives-and-tape/gasket-material/fel-pro-10-x-26-x-1-32-in-rubber-and-fiber-gasket-material-sheet/67683_0_0/
And I will make this guy famous short and sweet and to the point.
Robert
Isn't the same part for even later model stuff? 237/285/300? Should be available at local Mack dealer then?
I just did the hammer trick to make a gasket for my compressor mount. Didn't want to go through the hassle of buying one at Mack, got some paper and made it.
I've got a box full of random gaskets for a 673. Can't guarantee there are ones in it? I can look around if you like. Not really sure what they look like or the sizes(as my 673 is all together). Can you post up nice full size pictures?
Not sure on getting them from Mack, I just figured they would not have them. I'll get some pics up later. The hammering won't work on for what I'm needing, two are for the thermostat and one is for the housing that is raised and not flat.
Edited by medicpelle
These your gaskets? Got mine from Watts Mack.
post-3242-0-54647900-1447368492_thumb.jp
Yes they do, talk to Barry at WATTs and tell him you are from BMT (here) so does NAPA if they will look for them in a paper catalog not the computer. Paul
