Hello everyone. I recently lost my low range. I pulled both rear inspection covers and had someone split gears while I looked inside. Looks like shift fork is moving but not fully engaging. I tried to help it with a pry bar with no luck. It almost seems like fork is holding it back. I thought maybe bolt on fork came loose but figured if that were the case I could have manually pushed it back. I haven't pulled the rear top cover yet as it is very tight between cab. How far does cover have to come up to get out? Is there something that would limit movement on top cover? Any help would be greatly appreciated. Thanks, Justin
https://www.bigmacktrucks.com/topic/42684-12-speed-help-please/
Welcome Justin
The trans top cover on the high low should be able to fit out between the cab floor and the top of transmission
I have the bolt the holds the selector on the high low drop out once and had the same thing as you describe happen to me
Paul
https://www.bigmacktrucks.com/topic/42684-12-speed-help-please/#findComment-311674
  • 1 year later...
