Was going to adjust clutch & can't find adjustment mechanism; or just don't know what am looking for; clutch brake works fine but pedal lets to far up for my liken; seen a lot of different styles in my day but not like this; unless I missed it; anybody know about this type I would appreciate any information; thanks
https://www.bigmacktrucks.com/topic/42723-2012-mack/
the clutch I used to have has a 5/8 spring loaded bolt for adjusting.
No cover like the others.
bar engine over til bolt is at bottom. box wrench, push in to release and turn
. Be sure to wiggle a bit to make sure the head is locked
https://www.bigmacktrucks.com/topic/42723-2012-mack/#findComment-311991
Check with the dealer by serial # if the truck was equipped with a Solo clutch. If you rotate the clutch 360 deg. And only find a tab with a channel to slide that tab left to right it is a self adjusting Eaton Solo clutch. They are quite common but in most cases I install adjustable clutches when replacement time comes due.
https://www.bigmacktrucks.com/topic/42723-2012-mack/#findComment-312025
Yea that's what it is; Thanks
https://www.bigmacktrucks.com/topic/42723-2012-mack/#findComment-312066
