Not real familiar. Brimont was a French military chassis builder so if it has a Mack/Renault engine, parts can be tricky to get. Getting a new Cummins 8.3 sounds great but I couldn't help with what issues you will have putting one in your truck.
Is the Mack damaged or blown up or what? Even with parts issues, it may be more cost effective to fix what you have instead of reinventing the wheel.
https://www.bigmacktrucks.com/topic/43082-ottawa-brimont/#findComment-315654
  • 7 months later...
Ottawa-Brimont "Commando" (the French Unimog)
  • 4-wheel drive
  • 4-wheel steer
  • center pivot
Brimont ETR articulated 4x4 built at Rethel, Ardennes, from 1974 to the end of the 90s. They had a distribution agreement with Ottawa between 1986 and 1998. Brimont was taken over by Legris Potain Poclain PPM in 1989. CAT distributor Bergerat Monnoyeur bought the Brimont off-road vehicle unit in 1987. In 1989, the company was called Brimont PM. Off-road vehicle production ended in 1993. Brimont today is a small trailer manufacturer.
http://s3.e-monsite.com/2011/03/16/786277084x4-brimont-bergerat-monnoyeur-pdf.pdf
http://s3.e-monsite.com/2011/03/16/23346963brimont-p-l-12-5-pdf.pdf
http://www.monnoyeur.com/Website/site/eng_accueil.htm
https://www.bigmacktrucks.com/topic/43082-ottawa-brimont/#findComment-341307
On 12/13/2015 at 9:05 PM, Idahounimog said:
Anyone familiar with these trucks. 86 ottawa brimont 4x4 with 4 wheel steering. I t has a 170hp mack engine that doesn't run.I'd like to install a new 8.3 cummins.any suggestion or advice.
Looking at the engine, what is that Renault engine's model number?
https://www.bigmacktrucks.com/topic/43082-ottawa-brimont/#findComment-341308
