jmk
:SMOKIE-LFT:
I have a 1965 b61 with a tryplex trans. The transmition grinds when it is in 5th high but it does not grind in 5th lo or 5th direct.
:SMOKIE-LFT:
That6 is the over drive gear and it will have a bushing in nther o/d gear on the main shaft. The bushing is worn out and letting the gear ride too far away or too close to the counter shaft gear. Went i worked on macks years ago there was a bushing that could be put in there with some machine worh but if it has been doing it long it will need a gear. The counter shaft has brgs on it but if it was bad it would have a noise in low split also. This this problem could be the rear out put brgt but i dought it. The rear box can be removed with out pulling front box. This some times happens when a trans has been run in O/D too much at low RPM. glenn
https://www.bigmacktrucks.com/topic/4315-tryplex-grinding/#findComment-22765
