Hello all! I have a CF Fire Truck and recently had the steering wheel restored. I put the wheel back on and all worked however now sporadically when I engage the turn signal the horn sounds... it does have a center horn button and that works fine... Same thing also happens when the flashers are engaged... Any advice is appreciated!!
https://www.bigmacktrucks.com/topic/43261-f-model-steering-problem/
Some where a ground is loose and the easiest path for the signal circuits is through the horn button which works on a ground contact to complete it's circuit.
