Ive seen EUPs code when they are cold and go out when it warms up. If it runs fine you dont need to worry about it. Its more of a nuisance seeing the light come on. Will it be a problem? Maybe, maybe not. Is possible another EUP could fail before the one kicking a code. Im sure there are alot of guys on this site running around with the random EUP code. If the malfunction light doesnt bother you and the truck runs fine, I wouldnt worry about it.
Now that you mention it, it does only come on first thing of the morning when its cold outside once the truck is warmed up a little I never see it. I think you're right, as long as it stays running good I'm just going to let it ride. Thanks for the info
