Wondering if anyone can help me value two of my Mack trucks.
First one is a 1989 Superliner RW 713
E9 450 v8 15 spd day cab 20 frt 44 rears
Alum buds up frt and 24.5 on Daytons rear
Spring ride heavy frame
Second one
1990 ultraliner 500 E9 v8
12 and 40 Mack air ride bunk 12 spd
Has alum box but it was a tractor
https://www.bigmacktrucks.com/topic/43330-looking-to-value-two-of-my-mack-trucks/
I will try and get some pics tomorrow. They are both original trucks not repainted or restored. I would like to sell them to some hard core collectors to restore. Both v8s run good but the ultraliner has a coolant leek that I am not sure where it was coming from.
Does a Canadian camelback have a bigger spread than a normal American camelback? I'd like to see the Superliner.
They can.
Horan had one MACK with a Fuller 15 speed in the early 1980's. It was basically a 10 speed with deep reduction. Shifting as I remember was Deep 1 Deep 2 Deep 3 Deep 4 Deep 5 than out of deep reduction to low 4 low 5 and shift to High Range through high 1 through 5. Never used Low 1, 2 or 3 gears. Ran it at Bromans Pit a lot and when we were at a site on Marcus Ave.
41 chev, getting back to the 15 speed. Does it go low enough for lowboy use? I don't like to have the clutch doing the work.
Not to but-in, 15 is the same idea as the 8ll just a few more gears. And yes with suitable rears, I think it is excellent for lowboy work.
Your input is welcomed. If you have 15 speed knowledge, you're way ahead of me. I've driven a lot of different trucks, but not a 15. What I look for, is a nice low gear, and that the rest of the rears are close together.
On the road, basically a 10-speed. Extra gears only used off road or starting. For close splits, 13 or 18 would be better.
Sent from my XT1254 using Tapatalk
A RT-15715 has a low gear of 15.40 and 1.00 in high gear,RTO-15715 has low gear of 12.10 and high gear of 0.79. RT-15613 low gear of 12.56 high gear of 1.00 RTO-15613 low gear of 12.56 high gear of 0.87.Joe D.
I have two 15sp's, one a direct and one over. Nice trans for both highway and offroad. When you're light use it as a 10sp and when you need the low gears drop in deep reduction. Has 2 air splitters, one for deep reduction and one for main trans low/high. Only difference is the shifter won't let you go into deep reduction on the high side split. Also has a deeper overdrive than 13sp. Just sayin, this is my favorite trans! Bobs Toy
100% correct. 8LL is a 13 speed. Horans was originally a power unit for a lowboy for PRATT for 5 or 6 years til they replaced it with a Superliner, so that says it works out well for low boy work. We converted it to a 3 axle dump with a Stecco Demo body.
Converting to a 13 or 15 will require probably changing rear ratios for it all to work well .
