I would like to replace the engine in a Mack DM895SX 1973. The motor is the old V8 ENDT866. I would appreciate some help with info regarding what engine will fit in this chssis. I would prefer an E9 or E7 but I don't know what changes it requires and how complicated it would be.
Thank You
Oren
https://www.bigmacktrucks.com/topic/4348-engine-swap/
Thank You
Oren
Most anything will fit into the chassis. I would go with an E-7 mechanical engine as the E-9 series are getting very expensive to maintain from my understanding.
I would be interested in your 866 when you are through with it.
Thanks,
https://www.bigmacktrucks.com/topic/4348-engine-swap/#findComment-23018
Thank you for your answer Rob.
Do you know if I can use E7 engine mounts in this chassis? and how will the E7 perform without the charge air cooler?
Thank You,
Oren
Hi Oren, unfortuneatly, I know very little about an E-7 as it is too new for me. In my opinion the E-7 should have some type of charge air cooling as it is designed for that. An E-6 series of engine would be almost a straight swap as the correct mount would be readily available in a salvage yard.
As far as running an air-to-air it would require some fabrication as the old trucks did not offer it as an option until much later. You would also need to change/modify your radiator for this application for hose routing. A later model radiator may solve this problem but I don't know off the top of my head.
Sorry I can't be of more help.
https://www.bigmacktrucks.com/topic/4348-engine-swap/#findComment-23021
