most block heaters were powered straight from a 110 source
nothing in the motor like a fuse, etc.
1) electric outlet has power
2) plug ends are clean
3) broke wire
4) bad unit
I tested mine running a generator-could hear the motor surge when I plugged it in
https://www.bigmacktrucks.com/topic/43514-engine-block-heater/#findComment-319990
I cleaned off the prongs on the plug, they had alittle corrosion on them. So then the truck sat for 5 days in -5 degree temps. When I jumped in to start... she turned over, spit and sputtered for about 3 attempts, and fired on the 4th attempt. I don't know if the heater was working beacuse A. the winchill was -30 degrees and B. I was too damn cold to reach in and feel the motor. Also the hood latches were frozen.
So I'm guessing it may have been working.
Again thanks for the info.
https://www.bigmacktrucks.com/topic/43514-engine-block-heater/#findComment-320787
