The speedo in my truck is going whacky starts out fine then after a while the needle will fall down and read about 40 mph slower than I'm going? I replaced the tailshaft sensor, and does the same thing, could it be the speedo itself? Yoke seems tight on tranny, truck doesn't throw any codes, thanks.
https://www.bigmacktrucks.com/topic/43536-95-ch-speedo-whacko/
What he said^^^. No board. Just a head and set the dip switches on the rear. Fairly common and you should have an electronic speedo sensor that ties into V-mac. The switches will be based on tire size, axle ratio etc. The dealer may need your vin and they can cross it over from there.
https://www.bigmacktrucks.com/topic/43536-95-ch-speedo-whacko/#findComment-323495
