Tensioner pulley
Go to solution Solved by Challenger,
  • Solution
8mm for the mounting bolt. I break it loose with an allen wrench and small cheater pipe. I cut a 1/2" piece off of the allen wrench, put that piece in a ratchet wrench and use them to remove the bolt. Then reverse order to reinstall the bolt.
https://www.bigmacktrucks.com/topic/43540-tensioner-pulley/#findComment-320346
