MS200P reverse lights fuse location?
Go to solution Solved by PANELIZER,
I can't find a fuse for reverse lights in my 1995 midliner. I built and installed a new rear light harness for it because the old one wore through between the engine and the frame and kept blowing the turn signal and brake light fuses. Everything works good now, but no reverse lights. All the fuses in the panel are OK. I tested for power at the transmission and got nothing, leading me to think there's a fuse somewhere else that is blown. Anyone else know about this?
https://www.bigmacktrucks.com/topic/43550-ms200p-reverse-lights-fuse-location/
I haven't checked the switch, but the lights worked fine the day before... Either there is a fuse somewhere that is blown, or I have missed a connection somewhere in my new harness. There has to be a fuse protecting this circuit. Besides I don't have power to the switch, so it's a moot point for now.
