If you right click or copy the url you click on the little chain icon in the reply and paste there that should put it in your post
or just right click buy the the blinking line thingy and paste
http://www.bigmacktrucks.com/
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320845
I do it by bringing up both sites at once .. start your reply here the switch to the other site and go to the top address bar, highlight and RIGHT click on it and click copy.. switch back to your reply, position the little blinky line where you want the link to be inserted, again RIGHT click and then click on paste..
Hope this helps
Brocky
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320847
think i got it thanks much
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320849
Larry, Just like every workplace!
Anyway, inserting a link.
When you respond , hit "More Reply Options" button in the lower right.
This will bring a header above the spot where you type. The second line of the header starts with the letter "B". Move your cursor/mouse/pointer thingy to the right about halfway across. There is an icon with a small green spot on the lower right with a white plus sign in it.
Click on the icon and a new small screen pops up with a spot that you can right click "paste" a link into. Then hit "OK".
The link will now be inserted into the reply box with your text.
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320940
Hope this helps
I always do that way and never had ideas of needing anything else for.
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320949
thats what i`m talking about can`t seem to find any place to stick the damn thing
That's what she said!
-Micheal Scott
Dunder Mifflin
Regional Manager
https://www.bigmacktrucks.com/topic/43618-refresher/#findComment-320950
