Hi,
Does anybody have an idea where I can get a replacement canister oil filter since Fram"s C147 is obsolete? The 505 I am working on also needs a fiberboard glove box, rubber for the brake and clutch pedals and most important a headlight switch.There is a strong possibllity that the water pump is getting ready to die... can these be rebuilt. any suggestion will help us greatly. Thank you Bob
https://www.bigmacktrucks.com/topic/4375-1948-mack/
Bob,
Try Barry at Watts Mack for your brake pedal pads, glove box, and headlight switch, etc. The Fram C147 can be replaced with a NAPA 1503, slighty smaller but fits and works fine.
The water pump can be rebuiilt at Arthur Gould Pumps Kingsport NY? , If you do a search on this website I have listed his contact info here before, cost is about $100 and does a nice job.
FireMack
https://www.bigmacktrucks.com/topic/4375-1948-mack/#findComment-23163
Bob,
FireMack
Firemack
Thank you! This is great info. Bob
https://www.bigmacktrucks.com/topic/4375-1948-mack/#findComment-23291
