I have a 47 mack , sending out the master cyl. and hydrovac units to be rebuilt, would like to clean out the brake lines before putting rebuilts back in, what is the best way to flush??
Its only my opinion, but I'd say if there are signs of corrosion in the lines that make you feel the need to flush them, they probably all should be replaced. I just got my International 1900 on the road after replacing all the lines, master, and calipers. It sat for about five years and (in my opinion) replacing all the lines and such was the only option as the likelihood of failure was too great for me to risk. I doubt there would be a solution that could be used for flushing that would be compatible with brake fluid and I would think it would be extremely difficult to remove ALL the solvent from the lines once you flushed them. Just my $.02.
https://www.bigmacktrucks.com/topic/4380-flush-out-brake-lines/#findComment-23243
