Navy Nears Completion of Largest and Most Lethal Ship Ever
the Enterprise incorporates twelve strategically-located Lockheed-Martin 50,000 terawatt laser guns, the result of decades of Pentagon research.
This point seems doubtfull to me unless an athomic bomb is used to power up those lasers :whistling:
This point seems doubtful to me unless an atomic bomb is used to power up those lasers :whistling:
This is all classified cutting-edge technology, and certainly not my area of expertise.
Phasers were at conception termed Photon Masers, as the laser was a relatively unknown. The term Maser was already established, a device with weapon potential that produced long-range coherent beams of electromagnetic radiation. Photon energy is directly proportional to the frequency of the electromagnetic radiation.
The modern photon concept was developed gradually by Albert Einstein in the first years of the 20th century (https://en.wikipedia.org/wiki/Photon)
The term phaser has more recently been redefined though as an abbreviation for phased energy rectifier.
Phasers release a beam of subatomic particles called "rapid nadions", which are then refracted ("rectified") through superconducting crystals.
While working in a patent office as a clerk!
All that became out of my knowledge field either since I passed by that part of theoretical phisics during my education.
But on the other hand when we talk about lasers I may say my dad spent the most part of his carreer working on them.
Particually he didn't design emission units but power supply equipment for them.
I am sure not himself but what I learned well from his talks is a laser has extremely low efficiency grade from its power supply.
Usually about 0.5% So if you want to burn or blast anything you need 200 times more of energy to do it with a laser.
The most important property of a laser is concentration of energy in time and space is extremely high.
When you focus rays on a microscopic point and radiate a power extremely fast material just evaporates out long before it would be possible to transmitt the heat to the surround and cool off.
For sure a doctored image----where is the beanie with the propeller on top???
Putin took it.
