Came across this on Facebook. It is some where in Vermontpost-426-0-63204600-1455568542_thumb.jpgCan you imagine calling the road commissioner
over this? "Truck seven to base" "Go ahead seven" "Can you send Darell the mechanic out to SH5 and have him stop by my house for a change of under wear from me!"
https://www.bigmacktrucks.com/topic/44016-mean-while-in-vermont/
Bet the installer in the shop has a black eye and a few bruises now. :whistling:
had that happen back in 88 in Red Bank NJ. crackhead forgot to lift the plow as he was crossing the railroad tracks doing 35PH, and the cutting edge hit the rail perfectly. stood a V-8 powered 75 DM800 straight up in the air.
had to get a crane to lift the truck off the plow and put it on the lowboy so i could bring it home.
it also ripped the front axle out of the truck, and almost knocked the fuel tanks off.
Happened with on Maria's Pass once too. Plow truck was plowing a wide spot where they can get turned around on a two lane highway. Turn around is just left over black top paved on a natural wide spot. No gravel or compaction and the driver hit a big frost heave hidden by the snow.
