Hey everyone. I had a tiny leak up high where the upper hose connects to the radiator. So I drained all the coolant and made my repair with JB Weld. But now I refilled the coolant and while idling to check for leaks and to make sure the're are no more problems, my truck is running hot. Temp gets about halfway to red. Coolant remains full, truck temp is hot, the heater core is cool, the radiator and lower hose connecting to the oil cooler is cool. Upper hose is hot, oil cooler is hot. I disconnected the heater core hose to check for an air pocket, but only got hot coolant. Any Ideas? I'm working on my 1999 Mack CH613 with the 355/380HP E7.
If not air locked, make sure no one put a rag inside one of the necks to keep dirt out and it was never removed. This happened to a friend of mine and drove him nuts until they found it.
I did the repair myself, no rags where stuck in the radiator. I did run the truck without the cap (cap on bottle mounted to the firewall, No radiator cap on Rad itself.) Is that maybe where I went wrong? I'm waiting for the truck to cool off to try with the cap on to see if it needed 10+ psi to build up or something. I also have a radiator testing kit where I could pressurize the system with a hand pump?
Update: I put the cap on and seems to be working now. I figured I needed to keep the cap off to add more coolant but looks like that`s what I did wrong. All the normal functions seem to be back. Thanks for the quick response.
