 I'm cleaning up the previous owner's  wiring in my 71 R685.  There is a switch box on the left side of the dash between the steering wheel and vent window. the switch is broke, and there is a wad of disconnected wires under the dash that look like they went to the switch. What is this switch and what does it do?
https://www.bigmacktrucks.com/topic/44293-early-r-mystery-switch/
Thanks for the help, and I've got another question. What side of the cab was the rear wiring junction block originally located? I know B models were on the driver's side, but under my cab I found about 12 wires in a loom, cut in two, above the rear of the trans, about middle ways of the cab floor. I don't know which direction to proceed to take the cable, in order to continue new wiring.
