1989 mcr Mack with 300 hp.  Engine brake is intermittent.  It used to cut out at around 1900 revs but now seems to about 1500 revs.  After that it cuts in and out.  If some one could tell me  where is the sensor located that would be appreciated.  Cheers from South Australia .
https://www.bigmacktrucks.com/topic/44327-engine-brake-switch/
or you could bypass the fuel pump and clutch switch and install a "Jacobs" floor mount foot switch, I personally like this set up as it will only work when you step on it, I have mounted them to right of the throttle....... I don't know if Aussie pedals are backwards if so, mount to the left of the GO pedal.
https://www.bigmacktrucks.com/topic/44327-engine-brake-switch/#findComment-327508
