Its probably the beginning of a synchronizer failure.  The synchronizer is what makes your range shift.  Mack had a problem with the pinch bolt for the synchro fork coming loose causing incomplete shifts.  If you never had a synchro replacement,  its the synchro.
https://www.bigmacktrucks.com/topic/44351-mack-310m/#findComment-327656
