Driver/left side of engine,   towards  the center.  It will have a 1/4" plastic airline and a metal airline and 1 plastic round connector.  If you remove the connector,  the solenoid should be blue.  Its normally painted over but once you remove the connector you will see the blue.
To add some info.
The DRV (valve) is located on the turbo discharge pipe.  The plastic 1/4" line on the solenoid is the supply airline.  The metal line on the solenoid runs air over to the valve.   This line can break around the solenoid or rub through around the turbo,  they can break anywhere but these are the most common.   Just a few things to look at while troubleshooting your code.
