New I-Shift with crawler gears can start off from standstill with 325 tonnes
Volvo Group Press Release  /  March 15, 2016
Volvo Trucks is launching a new member of the I-Shift family: I-Shift with crawler gears. The new gears, which are added to the automated transmission, provide exceptional startability for trucks carrying heavy loads in demanding situations. The system is entirely unique for series-produced heavy trucks.
Volvo Trucks' new version of I-Shift makes it possible to add up to two new crawler gears. This means, among other things, that the truck can move off from standstill and transport a gross combination weight (GCW) of up to 325 tonnes.
"I-Shift with crawler gears offers an entirely new scope for heavy trucks with automated transmission to regulate their speed when crawling slowly and reversing. The driver can haul a heavy load without worrying about getting into situations that may lead to costly standstills," says Peter Hardin, Product Manager FM and FMX, Volvo Trucks.
With the new crawler gears, the truck can drive at speeds as low as 0.5-2 km/h. This helps immensely during precision manoeuvres such as in construction and maintenance tasks.
"The vastly improved driveability and startability with the new crawler gears makes the driver's job far easier when operating in difficult terrain on slippery surfaces with heavy loads, such as at construction sites, in mines or in forests. The heavier the transport operation and the poorer the surface or the terrain, the more the driver gains from a truck with crawler gears," explains Peter Hardin.
For haulage firms carrying out heavy transport operations on demanding surfaces as well as regular highway driving, crawler gears also offer considerable flexibility and the possibility of improved fuel economy.
"I-Shift with crawler gears makes it possible to start off from standstill in extreme situations. Combining them with a suitable rear axle ratio that optimises engine revs at high speeds results in lower fuel consumption on the highway. This is a significant benefit to haulage firms doing this kind of work," says Peter Hardin.
Depending on application area, I-Shift is available with one or two forward crawler gears, and with or without two reverse crawler gears. Reverse crawler gears make it possible to reverse extremely slowly, which is a major advantage when reversing manoeuvres require immense precision.
Facts, I-Shift with crawler gears
- I-Shift with crawler gears is a further development of Volvo Trucks' I-Shift automated transmission.
- The new version of I-Shift has been specially developed for excellent startability and for driving at particularly low speeds.
- I-Shift with crawler gears can allow driving as slowly as 0.5-2 km/h and can handle starts from standstill with a gross combination weight of up to 325 tonnes, which is unique for series-produced trucks with automated gearboxes.
- The transmission is available as either a direct-drive or overdrive gearbox with one or two crawler ratios. It is also possible to specify two extra reverse crawler gears.
- The crawler gears are integrated into the I-Shift transmission. In order to handle the high loads involved, several components are made of high-strength materials. The gearbox is 12 cm longer than a conventional I-Shift unit.
- I-Shift with crawler gears is available for Volvo Trucks' 13- and 16-litre engines in the Volvo FM, Volvo FMX, Volvo FH and Volvo FH16.
Ratios, I-Shift with crawler gears
- In a gearbox with one crawler gear the ratio is 19:1 in a direct-drive gearbox, or 17:1 in an overdrive gearbox. (The ratio of the lowest gear in a regular I-Shift direct-drive gearbox is 15:1.) In a direct-drive or an overdrive gearbox with two crawler gears the lowest ratio is 32:1.
- The ratio of the lowest reverse gear is 37:1 in a direct-drive gearbox.
Links
See the film on Volvo Trucks YouTube channel (link)
See the animation on Volvo Trucks YouTube channel (link)
Download the images at Volvo Trucks image gallery (link)
