I have been looking for the computer boxes and the can bus control for hours, I pulled the interior apart, took the seats and all the panels out and even looked under the hood and cab !! what's wrong with this picture ?
tractor is a 1974 R model.
thank you..
happy 4-1-16
https://www.bigmacktrucks.com/topic/44614-mack-computer-boxes-and-can-bus-control/
It does control the pressure.  Sometimes the 7th fetzer valve in the DPF screws up which can be solved with the application of 30 weight ball bearings and a torque wrench set at 275 ft lbs.
