I have a 98 ch 613  same thing happened I had to put a new speedo head in .
it was about  450.00 dollars. Mine came with a chart to set up for the correct speed.
I think it is close. The reason for the high cost Is the speedo head is electronic
good luck
https://www.bigmacktrucks.com/topic/44653-speedo-not-working/#findComment-329522
Before you spend that much money on a speedometer, check the speed sensor on the rear of the transmission. Check the wiring and plugs as well. If it is the sensor, you wont have cruise control either. if that still works, it likely is a speedometer.
https://www.bigmacktrucks.com/topic/44653-speedo-not-working/#findComment-329524
