In the early 1950's GM used the experience gleaned from making their Hydra-Matic's for use in tanks( late WWII and pre Korea) to develop a practical automatic for heavy trucks up to and including class 8. . Three ranges, seven forward gears and reverse gave it 16 gear changes.  Pretty interesting. Page 112 was 1/2 paragraph on warnigs about granny gear usage.      Paul
gm%20twin%20hydra%20matic_zpszapeh8jz.jp
https://www.bigmacktrucks.com/topic/44772-gms-twin-hydra-matic-1954/
What am I missing? Wouldn't 7 forward gearsX3 ranges=21 plus the 3 ranges in reverse for a total of 24 gear changes not 16?  Just curious if it was a typo or for example creeper range couldn't be used with gears 5, 6 and 7?  Good read at any rate.
Correct me if I'm wrong, but I believe the 8-speed Hydramatic was first developed for the M135 (single rear tire) and M211 (dual rear tire) two and a half ton 6x6s. And after being tortured and proven at Aberdeen, it was then offered to the civilian market.
(There were also M215 tipper and M221 tractor variants).
I think the M5 (Stuart) and M24 (Chaffee) tanks had 4-speed Hydramatics.
The article said that it would equal 21, but in practice there are some overlapping of ratios between ranges. Leaving a distinct 13 speed
Ok that makes sense, I figured there was something I was missing.
 M-5  and M-24 both had twin Cadillac 44T24  V-8 engines of about 110 h.p. each and a 4 speed Hydra-Matic model T-250 with a fluid coupling,  driving through a manual shift 2 speed transfer case, giving it 8 speed forward and 2 reverse.
M-18 and M-26 both used the Detroit Transmission's Torqmatic (built across the street from the Hydra-Matic plant) with used a Torque Converter, mainly for the heavier vehicle weight and 400 to 500 horse power engines engines .
You are correct on the G-749 family of trucks (M135, M211,M221 and M222)  All ran the Dual Range Hydra-Matic , with 4 speeds in two different ranges. All the driver needed to do was select the range he wanted. Single speed transfer case with Neutral.
The Twin Hydra-Matic was a pair  linked together. One in low range, one in high range with a 3 speed reduction box on the rear that gave it the split gears for a potential of in reality 21 speeds with about 3 or 4 of the gear ratios over lapping. It was originally intended for post WWII heavy Tanks but the M-46 to M-60 Tanks went to Allison Automatics in stead of the Hydra-Matics.   Paul.
Edited by 41chevy
