it really depends on the area of the country you are in as to what the axle between the drives and cab is called.
but technically it is a pusher, and when behind the drives it is called a tag.
https://www.bigmacktrucks.com/topic/45041-tag-or-pusher-axle/#findComment-332041
  • 1 month later...
  • 1 month later...
I think the term 'pusher' is more of a "Left-Coast" thing.... West of the Mississippi at least... 'round here we call them "Lift axles".... or a "tag" if it don't "lift".
https://www.bigmacktrucks.com/topic/45041-tag-or-pusher-axle/#findComment-341340
Here on D udder side of the world they can B called many things
specially when back in into a slot from the Road n the axle hangs U up hi n dry try n to get traction
LOL
In front of  drive axle ' Pusher axle'
B Hind drive axle  'Lazy Axle'
az well az all the above mentioned
Some were mounted an a weak set of springs with no oscillation linked from drive axle
:D
cya
§wishy
https://www.bigmacktrucks.com/topic/45041-tag-or-pusher-axle/#findComment-341342
