Otomobil Yayıncılık  /  May 5, 2016
The culmination of a four year program involving over 750 truck engineers and 2 million kilometers of testing, Ford Trucks has launched its 2016 vocational trucks product range.
At the heart of Ford’s new trucks is the Ecotorq series of engines which feature ultra-high pressure 2500 bar common rail fuel injection for enhanced performance and economy, and reduced emissions levels.
The biggest change in Ford’s vocational Cargo family is the big bore 13 litre powerplants. Construction Series family. The new 12.7 liter engines achieve peak torque from 1000 rpm to deliver new levels of driveability.
DLC (Diamond Like Carbon) coated pistons, a liquid-cooled air intake, improved cooling efficiency and reduced NOx SCR with egr'n work together.
A variable air compressor, two-speed water pump and active-controlled engine fan clutch all enhance fuel economy.
The Cargo’s ZF manual and AS Tronic automated manual transmissions (AMT) are both available with ZF’s legendary “intarder” auxiliary braking retarding system with up to 600kW (805hp) of braking power. Combined with engine braking, the Cargo now offers 1,000kW (1341hp) of overall braking power.
Cargo vocational models all boast smaller turning radiuses for enhanced driveabaility on the jobsite.
The Ford Cargo Ecotorq engine range:
Ecotorq 9L
Displacement                9 litres
Peak Horsepower        330 @ 1900 RPM
Max.                            1300 Nm @ 1200-1700 RPM
Oil Capacity                 30 litres
Coolant Capacity          35 litres
Ecotorq 13L
Displacement                12.7 litres
Peak Horsepower        420 @ 1800 RPM
Max.                            2150 Nm @ 1000-1300 RPM
Oil Capacity                 50 litres
Coolant Capacity          37 litres (55 litres with retarder)
Ecotorq 13L
Peak Horsepower        480 @ 1800 RPM
Max.                            2500 Nm @ 1000-1200 RPM
