Just finished replacing cups and injectors in an 08 MP7. Now about to run the overhead.  Its is stamped different than the MP8's I have done. an 8 would have 3 E 4, #3 intake and injector, # 4 exhaust. This 7 says 3 V 4. is this the same? Also do you line it up by the the first number that  appears to have a line through it or the line after the last number?  3 V 4 l example. couldnt make a line through the 3. Oh and one other thing, Is the adjustment for the injector, screw center bolt down until contact then tighten 4 flats and tighten jam nut, Iike an MP8?
Edited by c-mac
https://www.bigmacktrucks.com/topic/45509-08-mp7-camshaft-markings/
