  • 0
Question
1 answer to this question
  • 0
The tip turbine can probably be used if you can get all the tubing to match up. You need to check and see if the 250 is a Maxidyne or not, if not you may need a transmission with more gears or else transfer the pump and such from the 285 Maxidyne. Might work best to use just the 250 long block and dress it with the 285s pump, turbos, etc.. BTW, is this the Cruiseliner that sat along highway 19 east of Redwood Falls forever?
Answer this question...
