I have an Eaton pump that drives from the rear of the generator that has a serious leak at the shaft where it mates to the gen. The pump has these numbers on it 417099 800   and T9. I'm not sure if the pump has to come apart or if the seal can be removed and replaced from the outside. Of course this has to happen just before Macungie.
https://www.bigmacktrucks.com/topic/45633-b-model-power-steering-pump/
I was lucky enough to find a seal to make the trip to Macungie. Eaton was no help after about 10 transfers and a half hour. The old seal had no number on it. Allegheny York (York, PA 717-266-6617) was able to match one up by dimension 3/4 x 1.25 x  .312 (ID, OD, thickness). Also, in case anyone needs a pump Matt Pfahl had several in his flea market.
  • 6 months later...
