I have a 2009 mack cxu613 with a MP7 with a DPF filter and no DEF fluid. when under load and when not under load it as excess black smoke from the tail pipe. I have already cleaned out the EGR valve and the pipes. I haven't cleaned out the DPF filter yet. its has 568983km but I have no codes. should I b looking into dropping the filter and getting it cleaned next or should b I looking some where else?
https://www.bigmacktrucks.com/topic/45813-excess-black-smoke/
I also have another one same kind of truck with the same situation except the engine light is on.
the codes I have for this one is
P102 - Boost pressure
P105 - Boost temp
P411 - EGR diff pressure
P412 - EGR temp aftercooler
PP270 - ( I cant find what this is)
P096 - fuel level
https://www.bigmacktrucks.com/topic/45813-excess-black-smoke/#findComment-337684
no my egr is working properly. I would rather fix it properly then doing a patch job on it. I know my filters will have to cleaned out for sure but does anyone think my injectors could b going bad? would I have a code for injectors if it was going bad or a cracked injector?
my turbo has been changed already and my CAC and egr valve been changed twice.
https://www.bigmacktrucks.com/topic/45813-excess-black-smoke/#findComment-337849
DPF Restricting flo won't help the situation also the turbo could be stuck it will not throw a code for a stuck turbo either How ever you ve changed it so injectors seems possible! Clean the dpf see if it helps you got to do it anyway Your not going backwards!
Edited by fjh
https://www.bigmacktrucks.com/topic/45813-excess-black-smoke/#findComment-337874
@fjh yea I had the dpf sent out to clean already and it failed. The dpf filter is no good. so will have to be looking at getting another dpf for this unit. But I will b having a look at the injectors just in case. but the dpf was part of the problem
https://www.bigmacktrucks.com/topic/45813-excess-black-smoke/#findComment-337948
