Hi
I have a 2005 cv713.
My fuel gauge has been erratic recently.
Yesterday, all my gauges quit working. I checked the fuse in the cab fuse panel. Fuse was good.
I checked power to the ribbon cable on the back of the gauge panel. I have power to the upper left and lower right positions only.
Am I missing a fuse position?
I replaced the gauge panel (white) last year do to numerous lights being out for the gauges.
please help
thanks
Bruce
https://www.bigmacktrucks.com/topic/45887-all-dash-gauges-not-working/
i ended up replacing the ground with a wire bolted from the dash frame to a wire i soldered on the printed circuit board. it had something to do with where the ribbon wire plug went into the cluster.
  • 1 month later...
I have a 07 CL733 that has the dash panel problem where the gauges go off and seat belt light comes on and the buzzer goes off.I have the sevice bulletin for pre 02 models for the fix of this problem.My question is does anyone no if this servise bulletin pertains to the 07 models.
  • 6 months later...
  • 4 years later...
