50 minutes ago, ken 903 said:
This are the numbers stamped on the shells mate.
Ken, those are not the part numbers you want to try to buy.
Each Mack bearing half has a different stamped number (for Mack internal engineering purposes). The actual part number for both halves sold together is different. Your Mack dealer can supercede the number stamped on either one of the bearing halves, to arrive at the actual part number you can buy.....2 halves in a box.  Understand?
Those stamped numbers do tell you, the "P1", that you have standard size bearings.
