On September 2, 2016 at 8:36 PM, Keffer inc said:
how was your truck running before you did injectors? I'm thinking mine may be bad now instead of a boost issue. No matter what gear or loaded/unloaded, about 1,500 RPM is when it starts to shake and loose power. Feels like a misfire,
Fuel is what makes the boost;
when i r&r the injecters it made it seem like it had the 505hp; it will pull bury the needle now 40psi
  • 3 years later...
i agree on boost leaks. those manifold know to crack around bolts holding them.
do pressure test and check it visually for any cracks.
also what you guys should do from time to time is cleaning the boost pressure sensor, if the truck is not deleted it will even require this cleaning more often.
