My RS has a five speed and that is great for its intended use but I use it for a parade truck and need something with a double reduction . I have to use the clutch way to much during parades and I notice the nine speed in my truck at work has a double reduction and that would be perfect. I was offered a six speed but know nothing about them and don't know if it would be any better than what I have now.
https://www.bigmacktrucks.com/topic/46045-looking-for-a-different-transmission/
If the offered 6 speed is a T2060 then it has an air shifted hole gear.  The ratio is 9.02:1 which is much deeper than your 5-speed with a 5.24:1.  To install you will need to cut down a drive shaft because the transmission is about 8 inches longer and you will need a shift knob with toggle switch.
If the 6 speed is a T306G, it will have a 1st gear ratio of 7.5:1.  It would fit the same as your 5-speed and should be a simple swap out.
TRXL107 6 speed has a low first gear ratio of 14.10 and the high side is the same as your existing 5 speed. TRX107A is air shift version.
TRXL1071 has a super low 23.08 ratio. TRXL1071A air shift.
Looks like I'm going to buy the transmission from this guy he wants 300 for it came out of a 75 R model he says its in good useable condition I'm going to pick it up next week is 300 dollars a good price for a six speed? I still dot know what model trans it is he says I may still have to shorten the drive shaft due to the longer cone on the back for the output shaft.
