International Introduces Predictive Cruise Control for ProStar, LoneStar Models
Transport Topics  /  July 13, 2016
International Truck, a brand of Navistar International Corp., announced that it now offers predictive cruise control technology as an option on its ProStar and LoneStar Class 8 on-highway models to improve fuel efficiency and driver retention.
The system will monitor driver speed, engine load, weight and road grade to optimize the vehicle’s performance based on the road ahead, according to the company.
Unlike conventional predictive cruise technology, International's predictive cruise control uses preinstalled GPS maps and the latest commercial route data to make adjustments to cruising speed without the need to pre-drive the route, the company said.
“We’re seeing data indicating that this technology can increase fuel efficiency by up to 4%, depending on loads and routes. And on some very, very hilly routes we have seen higher savings,” said Denny Mooney, Navistar’s senior vice president, global product development.
Mooney spoke during a conference call to discuss the new feature.
He said International spent two years developing the needed control-module algorithms and software using both a computer-based simulation process called ‘hardware in the loop’ as well as actual road tests of the trucks.
The system uses mapping software from Navtech, Mooney said.
The pre-programed map covers the major U.S. highway systems “where you are going to get most of the truck traffic,” he said. “I envision we will upgrade the software to continue to get as many road systems as we can in it.”
International Rolls Out Predictive Cruise Control for Class 8 Trucks
Heavy Duty Trucking  /  July 13, 2016
International Truck has announced it is now offering predictive cruise control technology as an option on its ProStar and LoneStar Class 8 on-highway truck models.
The proprietary system uses preinstalled GPS maps and the latest commercial route data to make adjustments to cruising speed without the need to “pre-drive” routes.
“Because the GPS maps and route data are already loaded, this smart technology will enable fleets and drivers to obtain greater fuel efficiency and reduced emissions right out of the box,” said Denny Mooney, senior vice president, Global Product Development. “As a result, drivers who frequently run different routes will experience the same benefit as drivers who are used to driving a standard route.”
Predictive cruise control optimizes cruising speed based on topographical GPS data inputs to help maximize fuel economy. International’s system monitors driver speed, engine load, truck weight and road grade to optimize the vehicle’s performance based on the road ahead. As the terrain changes, the predictive control modulates cruising speed to correspond to the topography.
“We’re seeing data indicating that this technology, when coupled with a Navistar or Cummins engine and an Eaton transmission, can increase fuel efficiency by up to 4%,” said Mooney. “By reducing the need for drivers to make frequent adjustments to the terrain, the system makes vehicles easier and safer to operate, thus helping our customers attract and retain new drivers and be more successful.”
In a July 13 conference call with reporters, Mooney explained that the predictive cruise software developed by Navistar incorporates mapping “so geographic features and major highway systems used by over-the-road trucks are built in.”
He said the system “looks ahead and knows what’s coming up and optimizes the most fuel-efficient way to operate the truck.” The predictive cruise will speed up as much as 5 mph over the set speed, then will let the speed drop down as much as 10 mph below set speed as need to help conserve fuel even when going up and down hills.
“It will vary speed and prevent engine braking to prevent downshifts,” he added. “The 5 and 10 mph variances can be reduced per driver or owner preferences. But [changing them] might reduce the ultimate efficiency of the truck. Ours is a little different than existing [predictive cruise control] systems which have to ‘learn’ the route, then change shift and throttle settings.”
Mooney also pointed out that because drivers may not expect the truck to speed up or slow down, “a lot of driver training is required to get driver comfortable” with predictive cruise control.
The optional system has its own stand-alone control module and communicates over the industry-standard J1939 data bus.
While International’s Predictive Cruise Control is initially being offered on ProStar and LoneStar on-highway trucks, Mooney said it would be possible for the OEM to offer it on the aftermarket as well at some point.
He added that the new system resulted from Navistar’s involvement in the Department of Transportation’s SuperTruck program.
