It's rare but I have seen the main shaft twist and lock it in gear and the fork gets broken trying to get out of gear.   If you pull the shift cap and the fork is broke make sure you take a long bar or screwdriver and make sure the slider gear will come out and slide on the main shaft
https://www.bigmacktrucks.com/topic/46073-stuck-in-gear/#findComment-339871
