  • 0
Question
Hello all ,
just wanted to ask the pros a question .
Considering buying a 2007 Mack ct713 with
I-egr , internal egr they call it . Does anyone have any experience or insite into this ? Its a septic pumper so not a whole lot of miles a year as Rhode Island is very small . Anything i should be looking for when i go look at it ?
Thanks
larry
https://www.bigmacktrucks.com/topic/46268-2007-aset-with-i-egr/
2 answers to this question
  • 0
The I-EGR engine is probably the last production engine without tons of electronics. It's short coming  lack of low speed power and soot in oil due to more retarded injection timing. By 2007 Mack had cam/rollers problems figured out so it should be a fairly reliable engine and easier to work on than current cooled EGR/DPF/SCR engines. I normally drive in 1300-1800 RPM range with plenty of power. You won't be able to lug at to 1000 RPM. Follow oil changes religiously to keep soot down and it should work fine.
Good Luck
https://www.bigmacktrucks.com/topic/46268-2007-aset-with-i-egr/#findComment-340982
Answer this question...
