Does anyone know where I can get a water pump or water pump parts for a Mack ENF 707A? Someone rebuilt mine, but then didn't tighten the pulley nut tight enough. It wobbled on the shaft, causing both the shaft and the pulley to become badly worn. The key way is mushroomed on the shaft and the pulley is no tapered inside. The seals are good, the bearings are good, but the pulley and shaft are bad.
https://www.bigmacktrucks.com/topic/46374-water-pump-help/
It shouldn't be a big deal to have a machine shop re-create the shaft. If it is so bad that you don't think they can get accurate measurements you can get a shop drawing of the part from the museum for them to use.
The pulley should be easy to find, but if not the shop should be able to bore it out and replace the hub.
https://www.bigmacktrucks.com/topic/46374-water-pump-help/#findComment-341792
