You can check your codes with the cruise control switch's, but you must have a stored code (ie, CEL stays on) You do itby having key on, cruise power switch off, and hold RESUME/ACCEL switch on until CEL light goes out. The light will start flashing the codes. It'll be a two digit #, with a slight pause between seperate codes.
