very carefully.
i can't explain how to do it, except it has to be in just the rite position and then it will practically fall out.
same for putting it back in. get it just rite and it falls rite in. if it is not just rite it will never go in.
sometimes it takes me 2 minutes to get it out and back in, other times it fights me all the way for hours.
https://www.bigmacktrucks.com/topic/46401-need-some-helpadvice/#findComment-341933
Yup, E doors are a pain.
The window sash channel where the window rollers go should be removed off the regulator arms to give to the glass shop.  They will use setting tape and hammer the glass into the channel so it can be reinstalled in the door.  Also, a good time to use WD-40 or PB Blaster to make sure the rollers work super smoothly.
I haven't had to work on an E door for about 15 years and I swore the next time would be too soon.
https://www.bigmacktrucks.com/topic/46401-need-some-helpadvice/#findComment-341945
