David Axe, Reuters  /  August 10, 2016
Britain used to boast the most powerful navy in the world. No more.
That’s a serious problem for allies like the United States.
Traditionally, Britain’s Royal Navy has been the U.S. Navy's closest partner. The two have fought together against most every foe. So any weakening of the Royal Navy also erodes Washington's naval power.
Today, however, the Royal Navy is a shadow of its former self. Government budgeteers have repeatedly, and excessively, cut the numbers of its ships, planes and manpower. It can barely patrol the United Kingdom’s own waters, much less project British influence abroad.
Though London officials now vow to reverse the decline, it might be too late. With morale plummeting, and its few remaining ships frequently malfunctioning at sea, the Royal Navy’s suffering might be terminal.
The timing couldn’t be worse. The West is mobilizing to defeat Islamic State, deter an increasingly aggressive Russia and manage China's meteoric rise as a world power. The British fleet's collapse is an object lesson for cash-strapped governments struggling to balance competing budgetary needs in a seemingly ever more volatile world.
Yes, navies are expensive. They require long-term planning, work and funding. In peacetime, the fleet’s benefit is often invisible, marked by the absence of overt conflict.
Yet navies remain crucial to national defense. Patrolling international waters with sophisticated sensors and powerful, long-range weaponry, they can respond more quickly to crises and bring more firepower to bear than can air forces (which require nearby runways) and armies (which move slowly).
Navies that die from neglect leave a void that rogue states, terrorists and criminals can quickly fill. It takes navies to keep an eye on vast ocean regions. Remove what was once the world's leading fleet, and you create a virtual security vacuum.
During World War Two, the British fleet was still dominant. On D-Day in 1944, it was able to send more than 900 British warships across the English Channel to escort the Allied troops who would liberate Europe from Nazi Germany.
As recently as 1982, the Royal Navy could quickly muster no fewer than 115 ships — including two aircraft carriers carrying jet fighters, plus 23 destroyers and frigates — to retake the Falkland Islands from Argentina.
Today, the British navy doesn’t even have jet fighters. It mothballed its last Harriers in 2010. It possesses just 89 ships. (By comparison, the U.S. Navy and Military Sealift Command, the Pentagon's fleet of support ships, have roughly 400.)
Britain’s fleet has declined amid steady defense budget cuts, from 4.1 percent of gross domestic product in 1988 to 2.6 percent in 2010. Reductions in 2010 sliced another 8 percent in real terms. As part of a defense review in 2015, London vowed to stop cutbacks on the fleet. But the damage has been done.
On paper, the Royal Navy's 89 ships include one helicopter carrier, six amphibious assault ships, six destroyers, 13 frigates, seven attack submarines and four ballistic-missile submarines. The rest are minesweepers, survey ships and other support vessels, many no larger than the U.S. Coast Guard's small patrol ships.
Only the six destroyers, 13 frigates and seven attack submarines can be considered true frontline vessels, with adequate sensors, weapons and protection to fight and survive in a battle with a sophisticated foe.
The other ships require escort through dangerous waters.
Roughly half the ships are in routine maintenance or training at any given time. Several others are committed to small standing patrols, which leaves just a handful of vessels to respond to emergencies.
But that's assuming there are enough sailors to operate the ships. The Royal Navy has shed people faster than ships. Britain had 39,000 sailors in 2000. It now has a little more than 29,000, at least 2,000 short of its authorized strength.
Fleet planners tried to address the personnel shortage by sidelining two of its most powerful ships. This summer, for example, the Royal Navy placed the large Type 23 frigate HMS Lancaster in “extended readiness”: It was tied up pierside, its crew assigned to other vessels.
Meanwhile, the new Type 45 destroyer HMS Dauntless suffered serious problems with generators and entered port for repairs that could last at least until 2019. As with Lancaster, the fleet dispersed Dauntless' sailors to other vessels.
With those vessels out of action, the Royal Navy's real strength dropped from 26 fighting ships to an unprecedented modern low of 24 [just 24 fighting ships available to call on!].
Last month, the new attack submarine HMS Ambush collided with a merchant vessel off Gibraltar. The sub suffered serious damage and limped back to Britain for repairs that could take months, if not longer.
That accident reduced the Royal Navy's undersea combat strength by nearly 15 percent. It was a stark reminder that Britain has almost no naval strength in reserve.
As budget reductions cut deeper, the British fleet withdrew from much of the world. Before 2010, the Royal Navy played a leading role in efforts to curb piracy off the Somali coast. British frigates formed the core of various international task forces that patrolled the Indian Ocean and Red Sea.
But in 2012, London quietly ended its permanent role in the counter-piracy efforts. Britain also felt the dearth of ships much closer to home. In January 2014, the resurgent Russian navy, which under President Vladimir Putin has embarked on an extensive modernization program, sailed a missile-armed cruiser through the North Sea.
The Russian ship approached to within 30 miles of Scotland. The Royal Navy's crucial job is safeguarding British home waters. But the only available warship, the destroyer HMS Defender, was at Portsmouth on England's southern coast. Defender took 24 hours to make the 600-mile journey to Scotland. It eventually located the Russian ship and, after the two crews exchanged a few radio messages, Defender escorted the cruiser away from British territory.
A few months later, Islamic State fighters swept through northwestern Iraq. The world mobilized air and sea power to help Baghdad push them back. The U.S. and French navies deployed aircraft carriers to launch air strikes on the militant forces. The U.S. Navy even occasionally positioned two flattops in Middle East waters.
But for the first time in a century, Britain could do little to help. It had no aircraft carriers capable of supporting fixed-wing planes. London had decommissioned its last — HMS Illustrious — in August 2014. Illustrious' Harrier strike jets had preceded the vessel into retirement.
Perhaps most damning, in 2016 the Royal Navy withdrew from the South Atlantic after 34 years of deploying at least one large warship  to deter Argentina from again trying to seize the Falklands Islands.
Under successive Labour and Conservative governments, London has consistently cut the Royal Navy for more than a decade, while denying that the cuts were detrimental to national security. The government pointed to several multibillion-pound shipbuilding programs for new frigates, destroyers and submarines, as well as an ambitious plan to build two new large aircraft carriers and outfit them with F-35 stealth fighters.
But the new ships are too few, too late. They are also too lightly armed to adequately replace older vessels. Much less to expand and enhance the fleet.
In recent years, the Royal Navy has replaced 12 old Type 42 destroyers with just six new Type 45s, which are larger and more heavily armed than the Type 42s but mechanically unreliable. In addition, there are too few to handle all the missions the older vessels once undertook.
The fleet is getting just seven new Astute-class attack submarines, to replace 12 old Swiftsure- and Trafalgar-class subs. As with the Type 45 destroyers, the Astutes are bigger and pack more firepower than the ships they're replacing. But like the Type 45s, the Astutes have proved difficult to operate. In any case, there aren't enough to cover all the areas the older submarines once patrolled.
Today there are 13 old Type 23 frigates in the fleet. The government has approved just eight new Type 26 frigates. Meanwhile, it is promising to build at least five smaller Type 31s to help keep up the fleet's strength. But the lighter Type 31s could lack the firepower and protection to be a credible deterrent to Russia's far heavier vessels.
Indeed, many of Britain’s newest ships are remarkably light. London has placed orders over the past two years for several small, lightly equipped patrol vessels. The net effect is a Royal Navy that's increasingly made up of small, underarmed vessels that maintain the official ship count, but continue the hollowing-out trend that has steadily sapped its real strength.
The new aircraft carriers are perhaps the best examples. The two Queen Elizabeth-class ships, which are 920 feet long and displace more than 60,000 tons of water, are the biggest warships Britain has produced. When they enter frontline service in 2020, they should restore the at-sea aviation capability that the Royal Navy lost when it retired its Harrier jets in 2010.
The Queen Elizabeths, however, were planned for a larger fleet. An aircraft carrier requires more planes and escorts than Britain can provide. The U.S. Navy, for example, never deploys a carrier without 60 aircraft aboard and a convoy of three or four destroyers and cruisers, a submarine and several supply ships.
The Royal Navy expects to deploy just one carrier at a time and keep the second at home. It projects that its new carriers will only deploy between 12 and 24 F-35s — too few to use the ships to their full potential.
In addition, assigning the vessels needed to accompany and supply the carrier — three or four frigates and destroyers as escort and a several supply ships to sustain it — would monopolize the Royal Navy's entire deployable strength.
A 60,000-ton carrier can accommodate 50 or more aircraft. London plans to buy just 48 F-35 fighters, which means many could be in maintenance or training at any given time.
Navies are indeed complex and expensive. Stop paying attention to your fleet, and it will go away. For Britain’s allies, there’s a powerful lesson in that.
Of course BC Mack is the expert, but one can sense the decline of investment in the Royal Navy, and Royal Air Force, was first felt in 1982 when Prime Minister Margaret Thatcher on short notice had to send the fleet, fleet air arm and air force to a far corner of the globe and evict Argentinian trespassers.
This superb video reflects a small part of that brilliantly executed operation, and the challenged caused by a lack of reinvestment. Two of the three V-Force members, the Avro Vulcan and the Handley Page Victor, were instrumental in sending a clear message to the invading army (The Vickers Valiant has already been retired in 1965). As the film mentions, the RAF's aging Vulcan bombers, that with their mechanical post-WW2 systems were suddenly called upon to save the day, were in a state of disrepair due to being just three months away from being scrapped!  There's no more beautiful aircraft in the sky than a Vulcan.
Note that the V-Force manufacturers were the same brilliant bomber designers of WW2, with the Avro Lancaster, Handley Page Halifax and Vickers Wellington (The Short Stirling, older and slower, was replaced by the Lancaster and Halifax as soon as possible).
I believe the last I read that the Obama Administration was cutting our naval forces down to pre WWII levels. I know submarines and "capital" ships are not being replaced as their service life is reached.     Paul
And tax payers don't think that terrorists and other enemies are watching and waiting to capitalize on the weak allies?  We are in deep deep trouble and won't wake up until the US folds and world war 3 starts unfortunately.
From an on going story on BBC, China has laid claim to most of the Pacific including Micronesia, Philippines, Spratly Islands, Hawaii, Northern Marinas, Marshall and Carolina Islands, and Antartica.
http://www.bbc.com/news/world-asia-pacific-13748349
The State Department (working closely with the Clinton Foundation) probably sold those property rights to China...
From an on going story on BBC, China has laid claim to most of the Pacific including Micronesia, Philippines, Spratley Islands, Hawaii, Northern Marinas, Marshall and Carolina Islands, and Antarctica.
Paul, they are claiming virtually all of the South China Sea as their territory (good luck with that), but not Micronesia (includes the Northern Marianas, Marshall and Caroline Islands), the Philippines, Hawaii and Antarctica.
  • 2 years later...
British Army decides to reduce its tank fleet size by a third
Defense Blog  /  April 20, 2019
The UK army’s fleet of Challenger 2 main battle tanks is to be stripped by a third, according to The Times.
According to the sensationalist media report, the British Army is planning to revamp only 148 of its 227 Challenger 2 tanks because of cost constraints.
Also notes that the remaining main battle tanks would be used for spare parts, though it said that some tanks could be patched up for deployment in an emergency.
This statement was a real shock to a number of military experts who voiced concerns over plans to cut British tank fleet. The “new” British Army would have 87 times fewer tanks compared with Russia.
In the decade after the end of the Cold War, Great Britain lost its tanks production and can now lose most of its tank fleet, which in 1991 consisted of nearly 800 combat vehicles.
Challenger 2 is a heavily armoured, highly mobile Main Battle Tank, designed for use in the direct fire zone. Its primary role is to destroy or neutralize armour. However, it has the ability to engage both hard and soft targets and can operate across a spectrum of high-intensity conflict, counterinsurgency and peacekeeping roles.
The vehicle is equipped with an L30 120mm rifled tank gun, firing both long rod penetrator and High Explosive Squash Head (HESH) ammunition natures. Secondary armaments are provided with a 7.62mm co-axial chain gun and a 7.62mm pintle mounted General Purpose Machine Gun.
The UK needs to upgrade its fleet of Challenger 2 tanks to be able to compete with a new generation of highly dangerous Russian tanks.
British Army outgunned by Cambodia after tank cuts
The Times  /  April 19, 2019
Defence chiefs have expressed anger that Britain is to mothball a third of its tanks, leaving it with fewer tanks than Serbia, Cambodia or Burma.
The military is planning to revamp only 148 of its 227 Challenger 2 tanks because of cost constraints, The Times has learnt. That would send the armed forces down to 56th in the global league table of number of tanks available.
The remainder of the Challenger 2s, which entered service between 1998 and 2002, are expected to be used for parts. It is possible that some could be patched up for deployment in an emergency.
Related reading - https://en.wikipedia.org/wiki/Challenger_2
Russia's new nuclear submarine Belgorod was launched at Sevmash submarine making factory in Severodvinsk on April 23. The submarine will be the first carrier of Russia's new ominous weapon - the Poseidon underwater drone. The underwater vehicle can be equipped with both conventional and nuclear munitions to strike aircraft carrier groups, coastal fortifications and infrastructure. The submarine and the Poseidon drones will undergo tests for two years before they can officially join the Russian Navy. The Poseidon underwater drone is capable of carrying nuclear and conventional munitions at large depths at a high speed. The Belgorod submarine is a revised project of Antey 949A multi-purpose nuclear submarine similar to the Kursk nuclear-powered sub. Military experts believe that Russia can use the Poseidon underwater drone only in the event of nuclear aggression against Russia as a retaliatory strike. The drone is very hard to detect as it can travel at large depths and build unpredictable routes.
Edited by 41chevy
