Auto traction control. When it lights up your automatic power divider in engaged. A ABS sensor detects a tire slipping and activates the power divider and the light comes on.
   Paul
https://www.bigmacktrucks.com/topic/46485-atc/#findComment-342723
correct, ATC is auto traction control, and slightly applies the brake of the slipping wheel.
the lightning bolt is the electrical malfunction light, some call it the check engine light.
https://www.bigmacktrucks.com/topic/46485-atc/#findComment-342752
