Based on my experience, an e7 is an e7, as In all the same. The 300, 350, 427, and 460 are horsepower ratings. They have different injectors, turbos, and cam timing. Oil coolers can be either the cast-iron barrel type or the flat tin type, will have different filter brackets depending but both will work. The manifolds are the same, so are the valve covers, oil pans, flywheel housings and flywheels.
